Axun Workshop - JVS / JAMMA Control-Box(CBOX) SuperGun
interested with the supergun.
If I order one, I would like to know which others components are supplied with the supergun ? Which cables ?
Thanks for your reply,
Chris
None. When u buy the super gun you get a Supergun and power cord. thats it. you need to buy extra what you need. this is normal for buying a supergun in arcade scene
The Axun website is down -- will it be back?
MY boy @roy sent me a Taito F3 unit. my darksoft multi board is in usa so i couldnt use it in the test.
anyways i heard that the taito f3 had problems on the CBOX. well this is not true, we played bubble bobble for 2 hours with no issues.
video is coming of the experience.
Where did this rumor start?
  • Like
Reactions: roy
Are you playing this on a PVM or via Upscaler like XRGB or OSSC?
Apparantly it's not an issue with PVMs, only with upscalers which are fussy with the csync.
we will tests the upscalers XRGB and OSSC
Please do, would love confirmation if it has this issue on Cbox for upscalers. The HAS SUPERGUN has Csync regen feature which is supposed to fix sync issues for F3 boards connected via RGB to XRGB.
Likely because of the Taito F3 + OSSC combination that needs both hardware and software updates to the OSSC itself due to the F3's unusual all even field order (and some other quirks?).
More info:
http://junkerhq.net/xrgb/index.php?title=OSSC_AV3_use_AV1_RGB_mod
https://www.arcade-projects.com/threads/the-taito-f3-sync.12343/
https://www.arcade-projects.com/thr...rsal-jamma-interface.14108/page-3#post-264820
Hello, last year you mentioned that a new board may be coming with USB connectors. Is there a status update on that perchance?
Taito f3 and f2 don’t work properly with sony BVM because they have non standard sync pulses.
Also capcom games like speed rumbler and bionic commando have problems
You either have to make a circuit to correct sync pulses ( between board and supergun) or there is a possibility to correct this in the maintenance menu of the monitor. There is a voice in one of the boards ( BK i think) which has a sync pulse correction)
Another way is to use H phase , which shift the image and correct the sync and then center the mage with H center.
that will not come until after summer or later, lots of things to work on for v3
Thank you for the update! Very difficult to decide on waiting. Aside from the USB addition, would you mind sharing any other planned updates?
I put in an order about six weeks ago, excited to join the Axunworks club!
The one thing I didn't order with it is one of the SCART cables. The first board I'm using it with is JVS, so I figured I won't need it for a bit. I know Axun added an extra pin for stereo audio, but I'm not sure how much I should care given it seems like most boards do stereo audio off-JAMMA. Do people usually use Axun's SCART cables or ones from somewhere else?
