I get this error in Naomi CF and if trying to write the game.bin to the cf card directly. I will paste a few screen shots later today.where do you get this error ? Got a a PrtScr ?
I am opening Naomi CF as administrator.You have to be administrator.I'm getting an error when trying to write files to the CF card either using Naomi CF or copying them directly to the card.
ERROR: Security Sector Patch
I am using a usb to cf adapter.
What operating system are you on ?
IIRC it won't work on Windows 10.I am on Windows 10 Home
Is there a utility that works with Win 10?naomi cf stopped working back in windows 7 after certain update.
I was looking for a tool to copy the GAME.bin and ABC.bin to a CF card for the new firmware, but it sounds like I should do it the old way until a new utility is created.gcfi.exe was my preferred tool and shoould work under windows 10 as well.
Be aware that it won't work with the newest firmware as that no longer expects an encrypted sector on the compact flash card.
Maybe we will see a new version soon that can be used for both the older firmware and the newer firmware?
Or are you looking for a tool to get the 2 id's from the compact flash card?
That means that you can just copy+paste the files on your CF. No need to use any program or read the Read ATA IDENTIFY DEVICE data from your CF anymore.
Just copy the 2 files to the CF and you are good to go.
Is it not just a matter of copying/pasting the files onto the CF? Since I netboot, I've not used the CF method, but does the CF not present itself as writable media on your pc for dragging/dropping files? That's the impression I'm getting, but I'm genuinely curious what the method is for CF with the new firmware.I was looking for a tool to copy the GAME.bin and ABC.bin to a CF card for the new firmware,
No it is not.Is it not just a matter of copying/pasting the files onto the CF? Since I netboot, I've not used the CF method, but does the CF not present itself as writable media on your pc for dragging/dropping files? That's the impression I'm getting, but I'm genuinely curious what the method is for CF with the new firmware.
T
GND serial ) to the Chihiro CN5 8 pin connector, as per the wangan maximum tune 1 manual, I get a error 26 media board malfunctioning
jumpers, not these dipswitch right?My first instinct is that there is a potential issue with the jumper settings that is causing the serial port to not communicate properly. I know some other hardware requires the jumpers set a certain way to function properly with certain serial devices.
of course a good first step is to get everything upgraded and region matched.
