RealMFnG
No. It's for the Daemonbite encoder. Works with PS3, MAME, and MiSTer.
in case of do you have couple of EZ Pad Hack PCB?No, that's totally fine if that's easier for you.
do you have the map about connector I will wire it directly:
It would be on his website if he did.in case of do you have couple of EZ Pad Hack PCB?
daddy wants this
Hey @Arthrimus, if you ever see this post, I am struggling with programming the ATTINY87. Using my Xeltek 610p and an SOIC adapter to program it externally doesn't work right. I am not able to activate the button mapping features.Also a tip about the order of operations for assembly. You can add all of the SMD components first, but make sure you program the Home/Select emulation chip before you add the button remapping chip. If both are installed before programming the Home/Select chip you will get bus conflicts on the ISP bus and the emulation chip will fail to program. In the event that you accidentally do this anyway, you can still program the Home/Select chip, but you will have to have the JAMMAizer plugged into a cabinet or supergun to power the button remapping chip so it's I/O is floating and won't interfere with your programming operation.
