MostroVeneno
Top 5
1 - cps1.5
2 - cps1.5
3 - cps1.5
4 - cps1.5
5 - cps1
1 - cps1.5
2 - cps1.5
3 - cps1.5
4 - cps1.5
5 - cps1
Yea... reduced slowdown.haven't noticed any differences with gameplay other than reduced slowdown, which doesn't seem like a bad thing at all. Are there any documented problems with these?
The speed issue has been discussed to death on many threads, like this one: https://www.arcade-projects.com/thr...rystal-oscillator-to-upgrade-an-a-board.5721/I think it's important to make a clear distinction between incorrect speed and reduced slowdown. When I hear "incorrect speed" I think that the gameplay loop is running too fast. That is a problem worth worrying about. But I don't think that's happening in any of these games. And that's what I'd like to know, if anyone has experienced that.
have you read the sticky? https://www.arcade-projects.com/threads/what-donor-board-to-use-for-the-cps1-multi.13106/What about this “C” board?
No I haven’t, but I will now.have you read the sticky? https://www.arcade-projects.com/threads/what-donor-board-to-use-for-the-cps1-multi.13106/
What about this “C” board?![]()
It has the B-21 and looks to never had the battery installed from the factory.
I tested and have continuity between B-21 pins 45&46 and 5V, can I just lift those and tie them to ground(no visible trace to cut)?
I followed the instructions in this thread so hoping I’m good to go.That board, even having the placeholder to install the battery, doesn’t have the capability to be key-programmed.
It lacks some components and traces that model 90631C-5 has, such as some diodes and resistor to avoid battery-powering the B-21 while the PCB is running on a cab, and some traces required to send the proper signals to B-21 to be programmed. So, that board will only work with patched romsets prepared to be run with B-21 in default mode (without decryption)
Saying that, it is possible to tune it up to make it behaves like 90631C-5 board. For the particular case of upcoming Darksoft multi-CPS1, battery-related stuff are not needed, but signal programming stuff are.
That modifications were only theorized initially, but we recently tried it with real PCB with success, so it could work and that could be a valid option to run the entire catalog.
Anyway, it is not an easy stuff to perform as it involves smd soldering and tracing here and there.
I think more details will be posted when it will be released.![]()
Agree 100% here.There's too much fuss these days over correct speeds, pixel perfection, what's missing, what's not right and not enough fuss over actual gameplay IMO. I grew up playing on RF and composite and if that's all I had today, I'd actually still enjoy my time playing whatever I could get my hands on.
I quote this segment at least once a month or if I hear a name that's even remotely closer to Dylan. I absolutely love it and I thank you for posting it.
After doing this procedure, should I replace the battery again?Right, I get that we're tying 45&46 to ground via pin 47. What i'm trying to say is rather than mess with those very close pins, why not take the jumper wire connected to 45&46 and just swing it over to ground somewhere else. That way you're not risking bridging the pins?
You can definitely do it, without any support in the multi you could rig two crystals to a switch to manually choose 10 or 12 mhzI will ask my question again for the OCD crazy guys, what about the idea of a socket for the crystal oscillator to switch between 10mhz / 12mhz, (a lot of old long boards are dead but likely have perfectly fine 10mhz oscillators), wouldnt this be easier than switching out A-boards every time? Are the oscillators/pins too delicate for something like this?
If you want to get fancy, If someone makes an oled selector, have them add a dual osc. mod that switches to either based on game selected or manuallyYou can definitely do it, without any support in the multi you could rig two crystals to a switch to manually choose 10 or 12 mhz
maybe @BladeZX can do something like that. Also, no need to get osc from dead boards, they are available.Sign me up!You can definitely do it, without any support in the multi you could rig two crystals to a switch to manually choose 10 or 12 mhz
