Home Arcade System
if you allow for serial data on HD15, like the the RT4K, SVS does, maybe there's something to do with all this down the line, just sayin'😇
https://consolemods.org/wiki/AV:RetroTINK-4K#Serial_Over_USB_/_HD-15
I mean the HAS is great at it is, I own 3, but this kind of thing and adding something like an esp32 chip could lead to a lot of cool software features (which could/should be open-sourced, I'm not asking to put in that side of the work, just adding ressources to have a built in webserver in // to setup stuff (like the esp32 does)
this could mean selecting a game profile on a webapp, and it would auto select a saved controller layout, turbo layout, if sounds needs to be reversed (bootlegs, sorcer striker/mahō daisakusen, others) tell the RT4K to select the right profile (and vertical or horizontal layout info for rotation)
I really mean just opening it more for options and to interconnect with other devices👍
Hello @RGB
Do you have an idea or estimate when HAS v5 + power supply bundle will be back in stock? Is there a pre-order or backorder / interest list?
Thanks in advance!
Reactions: RGB
took me way too long to post this, but I got a nice surprise with my jamma cable entenders, a bad ass HAS5.0 case that matches the green CPS2 cases quite perfectly I must say 🤩 congrats again and thank you Mike!
IMG_20250606_234544_exported_1099_1751793453507.jpgIMG_20250606_212357~2.jpgIMG_20250606_214328_exported_266_1751793663428.jpg
That actually looks really good 😍
Now I want one for mine 🤣
Reactions: RGB
