How to Net-boot NAOMI/Tri-Force/Chihiro Using Pi-Force Tools
When I tried to upload the Wangan_Midnight_Maximum_Tune_2_JAP_1GB.bin.dat to Chihiro type3 with its original security chip( Wangan_Midnight 2) by transfergame.exe, it showed that this game is not acceptable by main board. What's the matter? Thx
Arcade porn .. it's not a perfect 10 because it's not a Naomi 2 .. but it's gotta be at least a solid 8
I'm trying to understand the relay connected to the GPIO here.
You will understand after the first 10-15 times you have to open your cab to reset the Naomi after playing a game that wont auto restart .. which is all of the Atomiswave games and about 1/4 of the Naomi games.
easy way around the non-reset options for most games is to push the test button to enter test mode before selecting your next game.
My test / service buttons are inside the cab :( I'm too old and lazy to crouch down and unlock the coin box to blindly reach around inside the cab to push the test button every time.
My bad for mis-interpretation. I'm doing the home consolization route for portability and streaming vs a cabinet. My head is clearly in another place. It makes sense especially when you lock your cab back up, and the naomi has a panic attack. I can see myself, setting down a beer, kicking it over while trying to remove the panel time after time. :)
Awesome! That's why we share what we do! I love inspiring others and seeing new ideas I can incorporate also :)
.and to be honest I borrowed all that from other people. i just found it's what works best for me :)
This is true, however, if you are trying to play Atomiswave games - they do NOT reset with the test mode button and require a hard reset or the relay option to perform. That is the main reason I want to see an plug and play option for the hard reset/relay and not have to worry about it anymore and I would like to not have to use the test button work around anymore. Hoping someone does a harness with the relay that allows this to work (ready made).
Or even better a multicart for Atomiswave ;)
Along these same lines, does anyone have a standard network attached power switch with a reasonable API that we can toss a few packets at? A multi port solution would be interesting.
iv been trying to dowload https://github.com/chunksin/Piforce-Web but when i try to extract his file fro, his google drive link theres a data error. Anyone have another link to download for it?
That is a forked repo (with some updates)... try the original, it has different links.
https://github.com/dev-tty0/Piforce-Web
Specifically, see the most recent changes to the README
https://github.com/dev-tty0/Piforce...7f82cf1#diff-04c6e90faac2675aa89e2176d2eec7d8
Without zerokey, although using pi-force, the chihiro type 3 running Wangan_Midnight_Maximum_Tune_2B_EXP_512 still shows "gateway not found" in about 3 minutes. Because zerokey of chihiro is not available and is no compatible with zerokey for naomi, I has to burn my own zerokey for chihiro and triforce, but i cannot found the bin file of the zerokey for chihiro, need help.
