Same here, but just with the new Raizing core. Haven’t found the this issue with any other cores.So I just did a clean install of everything again, to ensure everything would be correct, but I am getting this weird behaviour where the coin mech is start according to mister, and start is the coin mech. Any idea what might have gone wrong here / where I might have falted? @invzim ?
Want to add that this was the behaviour when running the raizing cores so maybe it’s related to these?
i think u need the 15khz .iniI got around to plugging it in.
On my repro mini cute. The pSU does not stay powered on, so Im guessing the Mister is not drawing enough power on the PSU that was provided.
On my OG mini cute. I get a rolling image and am not able to get a stable or change settings with F12? DO I have to set the output to HDMI analog. Im using the Dsub analog port to SCART on my PVM setup
Can I change the INI file file from my Micro Sd on my desktop?
The MISTER is verified working on my SONY PVM but I'm not sure to how to test it on the PVM as it relies on JAMMA power with the Jamma expander.
Anyone know a good place place to start getting this troubleshooted and working?
@8bitforlife sent them to me to calibrate and I have run into issues and would love to get this completed for him this week.
That's for a different product..i think u need the 15khz .ini
Thanks. Should I do those setup procedures before I transplant me De-10 Nanao into the Jamma Expander?@hoagtech , you need direct_video and composite sync for starters.
https://irkenlabs.com/jamma-expander/mister-installation
There are some trouble-shooting hints here,
https://irkenlabs.com/jamma-expander/operation
It sure is a lot easierThanks. Should I do those setup procedures before I transplant me De-10 Nanao into the Jamma Expander?
, and DO use the screws to secure the DE10 - a couple of people have left it unsecured which caused a short which fried the Expander..Will do. I installed arcade feet there so it can rest safely on a gapIt sure is a lot easier, and DO use the screws to secure the DE10 - a couple of people have left it unsecured which caused a short which fried the Expander..
Is it really good to go through the whole 31khz boot sequence on a 15khz monitor?Regard X68000 MiSTer core ive managed to load it finally !
View: https://youtube.com/shorts/GLvS4SmLQc4?feature=share
31khz games doesnt work . only loads but the screen is rolling like in the menu when you load a 31khz game . How i managed to make it working to load is i changed on the video mode and sometimes ive put on try sync and menu game screen loads perfectly , but ive found this is not necessary since expander detects the rezolution by himself . Try to see how acts Daimakaimura or Final fight , i don't know how to explain the monitor acts , only i can film and show you .Is it really good to go through the whole 31khz boot sequence on a 15khz monitor?
