No reasons i would not work.Can I ask, is there any reason your patched U98 rom might not work with the existing switching bank eprom/HD mods in this thread?
Yes definitively ! The boot loader i made is not compatible with all the KI rom versions yet but it's ready to be used with KI1 l1.5di & KI2 l1.4.In other words, can this now be used for a dual KI/KI2 set-up using the dedicated KI2 U96 hardware, along with retaining the soft-reset and boot-test features before KI2 also?
There is already hardware diagnostics on the boot screen, the bong is retained (unless S1:7 is turned on).If you build even more on your new initial boot test screen it could prove incredibly helpful for diagnosing faulty hardware...Losing the blue screen and bong tone is a small sacrifice I think most will be willing to live with!
The blue screen was not providing any diagnostic, it's is dummy progression indicator of the decompression into RAM. It doesn't care if the content of the RAM is OK.
Better identification of the hardware faults is on my todo list (reporting which chip is faulty).
In the mean time i have started to implement an IDE detection check as well. (if IDE drive is not properly connected or not present it will report it)
If you change jumper JP30, don't you get the full 8Mbit EPROM mapped into memory? Wouldn't that be sufficient to do multi-boot, rather than bank switching two 4Mbit EPROM images on an 8Mbit chip? Especially since you've rewritten the decompression... don't you just need sufficient space to store the compressed blobs for KI1 and KI2?soft multiboot ROM adapter for U98.
Yes, a 8Mbit eprom could be mapped to memory, but sounds rom would still need bank switching (unless the control data sent to the ADSP contains the offset of the sound/program to play/execute, but i haven't found any evidence of it yet).If you change jumper JP30, don't you get the full 8Mbit EPROM mapped into memory? Wouldn't that be sufficient to do multi-boot, rather than bank switching two 4Mbit EPROM images on an 8Mbit chip
You are right, a software patch would be way better that adding any hardware.What's your plan for the multi IDE part? A CPLD that patches C/H/S writes? I haven't done much research into it, but a software patch seems fairly straightforward, if you can build the image properly
Achievement unlocked : One drive to rule them all !
ULTRA COMBO!!!!!!Achievement unlocked : One drive to rule them all !
Just out of curiosity, would it be possible to add some kind of cheat dipswitch?Achievement unlocked : One drive to rule them all !
Yes, this could be done, but i am not interested on doing so to be honest, i don't want to modify the gameplay.Just out of curiosity, would it be possible to add some kind of cheat dipswitch?
