But you're holding up 8 fingersI'm down for one. Thanks!
Yes, the FFB goes vía another connector and to another board.I have a question. If I replace a JVS IO board in a driving cab which has FFB with Multi JVS board, the FFB will still work, right?
I hadn't considered the mixed messages I've been putting out there. Noted.But you're holding up 8 fingers
I hate to be THAT guy but a quick summary of function would be very helpful..Ok guys. I'm gathering the parts to finally do this run but I need to know generally how many units I need to manufacture. Also since it is my first time collecting parts I might doa presale for this batch. Please express interest in how many units you want. I will be doing these by hand so I want to make sure it is worthwhile. Sound off!
It'll work right out of the box correct?You can configure the inputs and outputs declared in order to imitate other original i/os. This is goid because some games look for specific numbers. Also EVERY input is configurable. The real cool thing is you save profiles on the SD card that you can swap with the touch of a button.
Its not the same as the blast I/O. That I/O in the blast is to swap between Model 3 and Jamma with minimal effort.Is there a way you can use this in a blast city cab? or just mainly for Racing Rigs?
