They only ever unlocked for me after loading the image, loading the game, then rebooting yet again. Give that a try?Can anyone else using this test the Marvel Vs Capcom 2 UNLOCKED characters rom on their setup and tell me if it's loading up with all the characters unlocked? Or do you get it loading with 0 exp and no characters unlocked.
I'm not using WiPi, I'm just saying I don't think the unlocks don't show up until the game program has run once.@ekorz are you using the V3 WiPi image, or the newest v4 Wipi?
That would be awesome actually. Maybe even a setup video?The piforcetools is the name given to the set of python scripts used to netboot from a raspberry pi and this software image is one of a few available.
Some use an LCD screen you can attach to the raspberry pi GPIO pins and manually select a game, others use a website published wirelessly from the pi. This image gives you both options so you can use it in a few different configurations.
I really need to make an overview video to show it working and the options it offers! Much easier to see it working than explain it!
Thanks, that does look nice! I thought however this was doable with the Pi Force software which is why I am a bit confusedDloop, just use this method. Trust me, I was new to this a few months back and i went around and around in circles trying to work out what i should use... there is a LOT of scattered and not up to date info out there.I'm sorry, I'm completely new to the naomi netbooting (haven't even got the stuff I bought yet). Is this an alternative to the Pi-Force Tools mentioned in the other thread?
If so what is the difference?
And what's the preferred method of netbooting by people nowdays?
If you are going to use the raspberry pi to hold your roms and load them from that, you want this image for your raspberry pi to control it all.
This image will let you boot the raspberry pi with microsd card inserted and your roms on there, connect your phone to the wireless access point on the raspberry pi, and at the press of a button, tell your raspberry pi to load an image onto the naomi.
Look at this video. It doesn't show you how to set it up, but it shows the end result and how simple it is to load games.
I'm pretty sure it was doable, it just updated.Thanks, that does look nice! I thought however this was doable with the Pi Force software which is why I am a bit confused
Sounds awesomeI'm pretty sure it was doable, it just updated.Thanks, that does look nice! I thought however this was doable with the Pi Force software which is why I am a bit confused
This version has now been updated to run on the latest pis and have now added a bunch of new features which include the ability to use either the 16x2 lcd, a full colour lcd or the web version or even both at the same time along with the disabling of the memory check when loading a game.
TL;DR - this is the image to use for Netbooting
There is a .csv file on the sdcard you need to edit. Duplicate the MvC2 line and change the filename to point to the MvC2 unlocked ROM. Edit the title so you can tell which is unlocked.Quick questions how do i choose between mvc2 and mvc2 unlocked, as i have both .bin files on the sd card but it does not show up as a option in the list of game.
