think of other arcade games, with 68k processor and very similar graphic architectureWhat other platforms are potential condidates to run on Neo Geo hardware?
UPSCALE THIS BAD BOYWhat other platforms are potential condidates to run on Neo Geo hardware?
Man, I had actually asked Darksoft to see about making a multi for this little guyUPSCALE THIS BAD BOYWhat other platforms are potential condidates to run on Neo Geo hardware?![]()
There's someone already on a multi for the ngpc. I recently received this guy's Atari Lynx multi and it's awesome.Man, I had actually asked Darksoft to see about making a multi for this little guyUPSCALE THIS BAD BOYWhat other platforms are potential condidates to run on Neo Geo hardware?![]()
But I like your idea as well.
Okay, first - who is doing a "proper" one with an SD card because I WANT ONEThere's someone already on a multi for the ngpc. I recently received this guy's Atari Lynx multi and it's awesome.Man, I had actually asked Darksoft to see about making a multi for this little guyUPSCALE THIS BAD BOYWhat other platforms are potential condidates to run on Neo Geo hardware?![]()
If DS has the desire for a ngpc multi it would obviously be awesome!
Now if you just meant having the NGPC being playable on the NG multi, HELL YEAH!
Second, yes, I was saying maybe get NGP game run on the MVS/AES cart. A dream, I'm sure, but the topic came up.
Well, I think ANY extra bonus games that we can play on it would be awesome, hell, it's awesome already!i totally second the IGS PGM to neo Geo just to be able to play the killing blade and knights of valor
That'd be right.The fact that the mSD slot is sticking out, makes me believe that the shells will have a hole for easy access?![]()
it does verify after loading.... should be less in the final version.Super awesome job DS! That took less than 10 seconds to load!
Do that and I'll buy two!SO many 68k processors... no idea how to look up tile sizes...
Cave??
http://www.system16.com/hardware.php?id=803
PGM is definitely more powerful. CPS1/CPS2 are debatable cause the Neo Geo can do more graphically and has access to bank switching unless you're going with raw power of the 68000 even then neo geo is faster than the cps1', but screen size differences make porting a no go.My bet is on Alpha68k (Gang Wars + Prehistoric Isle 1930) it's the predecessor of the NEOGEO. It's very similar in hardware.
Has only a resolution of 256x224px though, so there would be borders right and left.
PGM/CPS1/CPS2 have a different screen resolution and are significantly more powerful than NEOGEO.
A known bootlegger is currently working on an illegal port of In the Hunt (M92). M92 has the same screen resolution but requires programming and redesign from ground up.
To what? Neo Geo?A known bootlegger is currently working on an illegal port of In the Hunt (M92). M92 has the same screen resolution but requires programming and redesign from ground up.
