ShootTheCore
Legendary
I can add it to my cart but when I try to checkout it says the cart is empty.Also available for preorder on Saveyourgames
http://www.saveyourgames.it/index.php?route=product/product&path=89&product_id=175
I tried now without problemsI can add it to my cart but when I try to checkout it says the cart is empty.
Tried again and now I can checkout but it won’t let me select a shipping option and it stops me there. Sent you an email.
Nope. That’s an EPROM programmer. The ProMan / TL86_Plus is a NAND/NOR programmer with high speed writing. It’s highly recommended IMO. A couple of minutes to program an entire SIMM, if that.is it possible to use top 3000 programmer?
Ok yeah - I hope someone will offer a service to reflash that guy!The 29F400
It only works with Standard SH2 cartridges
Ok - sorry for being dumb on this one.... where can I get a whole new cart with the new BIOS? I just want these SIMM's I just pre-ordered to work!@mathewbeall, no, that won't work just by reflashing the flash. That's a custom SH2. You need the SH2 either replaced or a whole new cart.
No, you don't need a new cart. The same cart will work. You just need to update the BIOS.Will the new repro carts coming out be any different than the original ones? Debating if I need to buy another one with the new bios... or if I should upgrade my older Darksoft repro cart.
New BIOS with be compatible with both original and UltraSimms, so you can use your original reprocart with original simms if you still like.Will the new BIOS only be compatible with the ultrasimms? I like that I can use the original repro cart with the original simms or repro simms. That is will the new UltraBIOS support the original capcom simms as well?
Is there any reason I wouldn't want to upgrade my bios. Do I lose any features or compatibility?
