Retro Hardware Capacitors LISTS
Taito Type X motherboard (G4S306-5)
Thanks to @penrhos for the repair thread.
35x Electrolytics:
6x 3300uF 6.3v, 10x24mm KZG
4x 1500uF 16v, 10x20mm KZG
8x 1000uF 6.3v, 8x12mm KZG
4x 1500uF 6.3v, 10x12mm FJ/KZ
4x 1500uF 6.3v, 8x20mm KZG
5x 100uF 16v, 5.5x12mm KMG
2x 220uF 10v, 7x12mm ST?
2x 100uF 16v, 6.5x6mm KME
5x Polymer caps:
5x 820? 2.5v, 8x12mm
Unfortunately due to a very busy period I've a lot of lists to add if you guys can compile a google sheet (or excel) file when posting a new list I'll be ablee to add it more quickly thank for your help and your work!
I'll try to add to the drive the lists posted here as soon as I can, doing that they'll be easier for peoples to find :)
I've compiled the list for DATA EAST "Joe & Mac Returns" hardware (Data East SIMPLE 156 Hardware | DE-0409-1)
This radial cap list can be applied to next games :
Joe & Mac Returns
Magical Drop / Chain Reaction
Magical Drop Plus 1
ps : Since i'm not sure if Mitchell hardware uses same capacitors , i will not put in the list the rest of games (Charlie Ninja , Gonta 2 , Osman)
* C57 - 1000uf 35V (Dia 11mm , Lead Spacing 5mm , Lenght 19mm)
* C55 - 10uf 16V (Dia 4mm , Lead Spacing 3mm , Lenght 10mm)
* C54 - 10uf 16V (Dia 4mm , Lead Spacing 3mm , Lenght 10mm)
* C53 - 220uf 25V (Dia 4mm , Lead Spacing 3mm , Lenght 10mm)
* C52 - 4.7uf 25V (Dia 4mm , Lead Spacing 3mm , Lenght 10mm)
* C43 - 10uf 16V (Dia 4mm , Lead Spacing 3mm , Lenght 10mm)
* C40 - 100uf 25V (Dia 5mm , Lead Spacing 3mm , Lenght 10mm)
* C38 - 100uf 25V (Dia 5mm , Lead Spacing 3mm , Lenght 10mm)
* C37 - 0.47uf 50V (Dia 4mm , Lead Spacing 3mm , Lenght 10mm)
Donkey Kong - 2 PCB board set
CPU PCB: Model Number TKG4-12-CPU
C1 470uF 16V Axial
C3 470uF 16V Axial
C5 220uF 25V Axial
C13 33uF 16V
C14 33uF 16V
C15 1uF 50V
C16 1uF 50V
C17 4.7uF 25V
C18 1uF 50V
C19 1uF 50V
C20 3.3uF 50V
C21 1uF 50V
C23 4.7uF 25V
C24 10uF 16V
C25 3.3uF 50V
C26 3.3uF 50V
C29 3.3uF 50V
C30 10uF 16V
C32 10uF 16V
C40 100uF 16V Axial
C41 100uF 16V Axial
C44 47uF 25V Axial
C47 1uF 50V
C48 10uF 16V
C49 10uF 16V
C50 10uF 16V
C51 10uF 16V
C52 10uF 16V
C53 10uF 16V
C54 10uF 16V
C55 10uF 16V
C56 10uF 16V
C57 10uF 16V
C58 10uF 16V
C59 10uF 16V
*C164 33uF 50V
C164 isn’t populated on all CPU PCBs – don’t populate it if it’s empty on your board.
Video PCB: Model Number TKG4-13-VIDEO
C1 220uF 25V Axial
C2 220uF 25V Axial
C17 1uF 50V Axial
C18 1uF 50V Axial
NARC
C39, C59 47uf 50v Radial Sound
C10, C13, C9 10uf 25v Axial Sound
C19 47 uf 25v Radial Sound
C20, C34, C55, C67 2.2uf 50v Axial Sound
C2, C6, C16, C48, C68 100uf 35v Radial Sound
C30, C57 1000uf 16v Radial Sound
C15, C21, C47 470uf 16v Radial Sound
C33, C46, C54, C43, C44 1uf 50v Axial Sound
C1, C2, C3, C4 100uf 16v Axial Cpu
C1, C4, C5, C6 100uf 16v Axial Rom
C1 100uf 16v Axial Control
Liquid Kids (Single pcb version)
Radial capacitors :
- C1 , C87 , C92, C93 , C125 , C126 , C128 , C130 : 220uf 16V (Dia 5mm , Lead Spacing 5mm , Lenght 10mm)
- C88 : 1000uf 16V (Dia 10mm , Lead Spacing 5mm , Lenght 20mm)
- C68, C79, C80, C81 : 10uf 16V (Dia 3mm , Lead Spacing 3mm , Lenght 10mm)
- C84, C86 : 100uf 16V (Dia 4mm , Lead Spacing 3mm , Lenght 10mm)
Please , is anyone who have the pcb and can tell me what value have the C25 ? On my pcb is missing !
hey guys i'm in the process of recapping a shitload of pcbs - i'm double checking them, and when they are finished i'll be dumping the cap maps here.
But there's something strange with my parodius da PCB - perhaps somebody here can shine a light on this.
The Konami PCBs have have the cap values printed on the silkscreen, but on this game the printed on values and the used caps are totally different -
C7 16v 1000uF printed and used
C12 16v 10uF printed, 50v 4,7uF used
C16 16v 100uF printed, 16v 47uF used
C20 16v 10uF printed, 50v 4.7uF used
C21 16v 220uF printed and used
C22 16v 100uF printed, 16v 47uF used
C24 16v 1000uF printed and used
C30 16v 1000uF printed and used
C32 16v 100uF printed, 16v 47uF used
C34 16v 100uF printed, 16v 47uF used
and then there are two unmarked 16v 4,7uF printed, 50v 4.7uF used
I know using 50v 4.7uF instead of 16v 4.7uF is ok, but whats with the other stuff? ?(
Same thing with Aliens...
I should have the caps for recapping both variants, i just don' want to destroy something...
Maybe someone before you already recapped the board partially but with different values, can you see if the solder joints are from the fabric or not?
Nanao MS-2933 Chassis
C721, C203, C232 - 100uf 16V
C407, C401, C381 - 100uf 25V
C406 - 100uf 50V
C971 - 10uf 16V (BP)
C924 - 680uf 25V
C332 - 10uf 250V
C930, C957, C960, C711, C927, C505, C503, C712, C723, C234, C201, C613, C609, C626 - 10uf 50V
C454 - 1uf 100V
C624 - 1uf 50V
C621, C230 - 2.2uf 50V
C922 - 2200uf 25V
C929 - 220uf 16V
C233 - 22uf 50V
C531, C532 - 330uf 35V
C506 - 330uf 25V
C608 - 33uf 50V
C722, C625 - 4.7uf 50V (BP)
C614, C636 - 470uf 16V (I used 35v)
C910 - 470uf 35V
C954, C961, C535, C353, C356, C202, C231, C104, C361, C362, C607 - 47uf 16V (I used 25v)
C953 - 47uf 250V
C923 - 680uf 10V
C905 - 1200uf 200V
C921 - 470uf 250V
C702 - 6.8uf 250V (I used 400v)
I copied this list from Neo Geo forum. Only difference I had that C614 was completely missing on my board (had solderpads still on factory tin and filled, so it was never there). So that might be missing on other boards too. Since it is under that metal cage, it propably would not even fit. I marked the place of this with black X on the PCB picture.
Drift Out (by Visco) on Taito F1 Hardware
Radial capacitors :
- C121 , C122 , C124, C88 , C78 , C1 , C26 : 220uf 16V (Dia 5mm , Lead Spacing 5mm , Lenght 10mm)
- C79 : 1000uf 16V (Dia 10mm , Lead Spacing 5mm , Lenght 20mm)
- C70, C71, C72, C62 : 10uf 25V (Dia 3mm , Lead Spacing 3mm , Lenght 10mm)
- C75, C77 : 100uf 16V (Dia 4mm , Lead Spacing 3mm , Lenght 10mm)
