BigSchmid
As someone with less than zero knowledge of 3d printers or anything of that sort, what would come after my interest in acquiring one at some point?
Are you asking me?As someone with less than zero knowledge of 3d printers or anything of that sort, what would come after my interest in acquiring one at some point?
Short term? No. Someday? Mayhaps.Are you asking me?
It’s not too hard to do. Just get the artwork you want off the internet - search Sega Lindbergh logo. Take that file on USB along with the measurements you want to any place that makes signs, placards, nameplates etc and ask them to make it up for you. The material is called Traffolyte. Here’s my proof they sent me before cutting and laser etching. I think it had an adhesive 3M backing. 122mm x 142mm.Short term? No. Someday? Mayhaps.
What is the thickness of the things? I don't recall if I got a good look at what your finished product by itself looks like..may have to go back through posts. How do you think silver that matches the cab would be best achieved?It’s not too hard to do. Just get the artwork you want off the internet - search Sega Lindbergh logo. Take that file on USB along with the measurements you want to any place that makes signs, placards, nameplates etc and ask them to make it up for you. The material is called Traffolyte. Here’s my proof they sent me before cutting and laser etching. I think it had an adhesive 3M backing. 122mm x 142mm.
It’s about 1.5 - 2mm in length thick. The material just comes in a number of colours with silver being one of them. So you’d just have to go with that silver.What is the thickness of the things? I don't recall if I got a good look at what your finished product by itself looks like..may have to go back through posts. How do you think silver that matches the cab would be best achieved?
that's looks amazing, I need to finish mine up and get a TTX!Lindy needs a friend...
As I understand the TTX and the LG monitor my cab both have switching power supplies and can be run on 100 volts.Or just any pc & jvs pac if using the multi.
So you have two plugs to the wall? one for the 4 way extension and one from the cab for lights etc?I made a shelf in mine & had a kettle 4 way gang extension:
