mR_CaESaR
Yeah that's the bootleg of the Chewlix
Can you take some pictures?Anybody done this to a Vewlix Diamond Black? I’ve got the monitor off, I’ve unscrewed all the sides but it’s still attached to the frame. Looks like it’s attached to the Plexi inside the frame too.
looks like there are more screws but they are all at a funny angle....
My guess is, the whole assembly should pull out. Try unscrewing the top and bottom. Additional screws could be holding the assembly. The pictures are bit too small. Can you email me with additional pictures? [email protected]So I’m not sure what else to unscrew or does it just pull out? Doesn’t feel like it. Just don’t want to break it.
Always nice to have numbers. Which bar were you getting those readings from with the Time Sleuth? The top or the middle? People tend to measure one or the other, so it's hard to know which they used.both are on the under 10ms of latency, they are about the same with my other Asus Monitors, I did test them with the time sleuth.
those readings I posted were from the middle part, I measured at the top of the screen as well and i was getting even lower numbers. From what I've been reading the middle part of the screen is what counts right?Always nice to have numbers. Which bar were you getting those readings from with the Time Sleuth? The top or the middle? People tend to measure one or the other, so it's hard to know which they used.both are on the under 10ms of latency, they are about the same with my other Asus Monitors, I did test them with the time sleuth.
1080p 32" panel is pretty ideal for 'normal' Vewlix upgrade use.
There are different schools of thought for "what counts", it doesn't really matter honestly, as long as you know where the measurements are taken for context.those readings I posted were from the middle part, I measured at the top of the screen as well and i was getting even lower numbers. From what I've been reading the middle part of the screen is what counts right?
Oh cool, I've been eyeing this monitor. I can't for the life of me find the 32MP58HQ-P locally anymore. However, the 32MN500M-B is available and from the specs it looks more or less the same only with the addition of FreeSync (which admittedly I have little use for).LG 32MN500M-B 9.30ms
But it would give you more options for the future to have it... You could add a Jammafier+Jassifier+OSSC at any time now and it will just display.which admittedly I have little use for
Oh I know, but I have enough CRT cabs for jamma stuff. I just want some purty LCDs in my HD cabs.But it would give you more options for the future to have it... You could add a Jammafier+Jassifier+OSSC at any time now and it will just display.
