plasticfactory
Is anyone working on a case / acrylic panels to mount it all?
I will be making something.
Has anyone tested this on the repro sound board? By looking at the datasheet for the TDA7240A amps, Im just not sure the speaker outputs can be bridged that way, but I could be wrong.I would recommend the method Taito used on a lot of their JAMMA boards.
so basically
Left Channel + to speaker +
Right Channel - to Speaker -
so long as the cab or super gun isn't grounding out speaker - this will allow mono cabs to play the output in mono, and Taito Cabs (like Egret II and Egret 29) to support Stereo through the JAMMA connector.
Aren’t you making something for the Gnet as well? Can’t wait.I will be making something.
I’m down for both.
J1 - Power input
Molex KK Series (.156")
Housing: 09-50-3071
Pin: 09-50-0106
Wire Gage: 18 AWG
1. Blue - +12V
2. Blue - +12V
3. Black - GND
4. Black - GND
5. KEY - N/C
6. Red +5V
7. Black - GND
J6 - Amplified Stereo Output
Housing PN: 09-50-3051
Pin PN : 09-50-0106
Wire Gage: 22 AWG
1. Brown - Speaker Left +
2. Gray - Speaker Left -
3. Volet - Speaker Right +
4. KEY - N/C
5. Gray - Speaker Right -
I ordered a simple pcb for now to use for power and to route speaker level sound back to the jamma edge.I didn't see it posted anywhere but here is the connector pinout information from the manual:
I'd buy one of those. There is definitely a right way to mix stereo inputs. A small resistor network is what I've usually seen. you could look at any JAMMA board that supports amplified stero and see how they mix it for JAMMA.I ordered a simple pcb for now to use for power and to route speaker level sound back to the jamma edge.
Does the sound pot control volume level of the line level outputs on the MB?
How do you mix stereo speaker level outputs to mono. Or does it even matter?
2nd. I'm in for a purchase.I'd buy one of those. There is definitely a right way to mix stereo inputs. A small resistor network is what I've usually seen. you could look at any JAMMA board that supports amplified stero and see how they mix it for JAMMA.
If you want to emulate the tattoo stereo over JAMMA the F3 supports it so you could maybe look at the circuit between the amp and the JAMMA edge for reference.
I'd like to get in on one of those PCB's too, if it's alright.I will tweak the layout a bit and order some pcbs enough to cover you guys.
Oh, Im not looking to make $$ on this, I will split the total cost per PCB so all you guys are paying is parts and shipping costs.
Looks clean. I'd like one too please @Derick2k thanks!I will tweak the layout a bit and order some pcbs enough to cover you guys.
