Yep, that's was my assumption too.Yes. I only mentioned SYG as @cps2 is in the UK
Ooh, sounds interesting. Can you share?Yes, more are being made and I've got a small suprise. They should be ready in 5-6 weeks.
Fortunately I had some header pins I could use. They don’t have the second support on them but I was able to get them to the right height. I had a few connections that weren’t flush and one of the solder points on the quick solder board wasn’t quite full, but after that it all works great now! Thanks!Yes, looks like there are some pins unsoldered there
Can you or someone in your area solder those missing pins? Should be pretty easy if they know how to use a solder iron.
I surely hope its small as I just got mine a a week agoIt's a small update, it will be announced when it's ready
Will said change be offered as an upgrade?same distributors. Price almost the same...
a connector for the key re-writing so you no longer have to solder wires to the multi.What else?
