A Freeware Taito TypeX Multigame
Does anyone have any ideas on dumping/flashing the gpu bios from the TTX directly? I have only read that there are issues in doing so. I tried to build a AGP based test system but still had issues…
Credits go to: @Niko for his DOS boot image :D
  • Write image to disk
  • Insert original PS2 keyboard. A USB to PS2 adapter will NOT work.
  • Connect VGA screen
  • See DOS boot up and feel nostalgic
  • cd TTX1GPU
info:
flashrom -i
save:
flashrom -s 0 original.bin
write:
flashrom -f -p 0 9600SE.BIN
Note:
The TTX has a watchdog on the JVS MASTER card which will reset the machine after 3 minutes.
If you want to make sure that your FLASHing session is not interrupted I would remove the cables going to the JVS MASTER card.
Please save your original BIOS and share it with us before flashing @AlxUnderBase !
https://pixeldrain.com/u/ejK6m3oQ
I am not responsible for any damage this might incur to your system. This is done at your own risk.
  • cd TTX1GPU
info:
flashrom -i
save:
write:
flashrom -p 0 9600SE.BIN
https://we.tl/t-tsACLh9B4q
Im almost ready . Hope tomorrow to find a proper way to test it 🙏🏻 Ive tried with an adapter usb to ps2 but is not working
View: https://youtube.com/shorts/9N-yBZ-OU1o?feature=share
I had to acquire an actual PS/2 keyboard for messing with my TTX/TTX2… not super easy to come by sometimes!
I dont know if i did something wrong or i missed something 😊
ps : orginal bios of my ATI 9600 gpu is hosted here ( https://we.tl/t-M6GVlvYMS4 ) - flashrom-s 0 original.bin i suppose did this file :happy:
@rtw : now remains to fix the menu . Games working amazing after loading each of them
View: https://youtube.com/shorts/h5xCHel7Bms?feature=share
@AlxUnderBase Nice to see you have it working somewhat. You should redo the operation with the command:
Then when that is done reboot and save the image to verify that it is the same as 9600SE.BIN.
And post it here. Just zip it up and attach it to the post, it is tiny.
@rtw : all went great with some nice sounds from MS Dos after flashing the bios . Now all games working amazing✌🏻
Thanks @rtw & @Niko 🙏🏻
New resulted bios is here : https://we.tl/t-CFOkoEXhp3
View: https://youtu.be/GRBXFMj_A8M
I misread or misunderstood, because I thought that the downloadable file was an image on the hard drive and they are just files that are copied to the hard drive since unfortunately I do not have any original hard drive with the operating system included to test it on my TTX :(
Looks like you are missing a PSU unit as well :)
Everything is there, read the instructions carefully... ;)
I read the entire thread but nothing. I can't find it, I only find the software that is copied to the TTX system OS but I can't find an image (.img) of the TTX OS, so what I am looking for is something similar to what Niko has (an OS image) . I do not have any original image of the OS since the hard drive that came with the TTX is totally dead 😓
