Might be useful for someone else, IDK? Anyways I got a Vewlix Diamond Orange recently. "SWEET!" I say up until I found out the 1080p panel has no aspect ratio options. "Oh NO!"
Well good news, you can modify the type x2 multi to work with this panel and make things not look like shit!
To achieve you need to obtain shutdown.exe from Windows XP. I just grabbed shutdown.ex_ from the i386 folder on an install cd and used "expand shutdown.ex_ shutdown.exe" from a command line.
copy to thumb drive, open command prompt:
copy f:\shutdown.exe c:\windows\system32\shutdown.exe
ewfmgr c: -commitanddisable
shutdown /r
open command prompt again:
rundll32 nvcpl.dll,dtcfg setmode 1 1920 1080 32 60
rundll32 nvcpl.dll,dtcfg setscaling 1 5
shutdown /r
and then open command prompt one more time:
ewfmgr c: -enable
shutdown /r
to revert change the nvcpl commands to:
rundll32 nvcpl.dll,dtcfg setmode 1 640 480 32 60
rundll32 nvcpl.dll,dtcfg setscaling 1 1
By default X2 is set to 640x480 and the dip switch when detected on a compatible game will change the PC resolution to 720p. These changes set the desktop resolution to 1920x1080 and enables the gpu scaling while maintaining aspect ratio. This makes all the games run scaled at 1080p resolution.
