Sounds like you have corrupted your disk in some way ?
What do you mean by the "reset line" ?
Very strange, looks like no disk is connected at all !
you are right . i removed the ssd and did the same . i removed sata cable from mb and connected back , connected back ssd and powered . now it works . lets check after the logs . ill be back with txt (i did "txtshell.txt." ) shortly
Reactions: rtw
@rtw ... anyway, i was received 2 new messages . in the txt i didnt seen something to be logged . anyway , i did pictures to be sure (i know isnt relevant but just to show you) .
ps : nevermind ... "ttxshell.txt." doesnt register logs . i did " ttxshell " and now we have some logs . i will test again and hope we will get that messages from pictures attached here
@rtw i did " ttxshell " and now we have logs
  • rtw - ttx1 tests.zip
Thank you for the logs. Will take a look later today.
What is the error message being shown from ttxshell displayed in your last picture ?
“ error malformed return packet 0 x 00000f29 “ and the other is in jap text
The malformed packet is interesting. What kind of IO are you using ?
Have you seen the malformed packet error before ?
I checked all logs and there are no errors logged. Did you enable logging before or after you got the malformed packet error ?
I checked all logs and there are no errors logged. Did you enable logging :D or after you got the malformed packet error ?
Logged was before after i figure it out the making txt file ive tried first “ ttxshell.txt. “ and then ive seen nothing in this and ive made “ ttxshell “ txt file and keept both and boot to see if something and where is logs writed and in “ ttxshell.txt. “ was nothing , but in “ ttxshell” txt was the logs . So … all logs are new from after ive figure it out .
Im using the chinesse IO because is handy and much near to my hands than taito io who i keep in the closet :D
That was the first time ive received that message “malfunction … “
Thank you for the information. The error means that your Chinese IO replied with a very strange size of a JVS packet. I might add some debug info to that later.
If you have a TAITO IO why don't you use that instead ?
If it'll help, I'm happy to translate the Japanese error message. Just need a clearer image of the error window.
Can't quite make out some of the kanji in the photo, but I believe it's saying it can't read from some of the memory addresses listed. Program has. shut down, click on to exit
Dunno if that helps or not
Tested little bit this morning with K91X1025F - TAITO IO :happy:
  • rtw - TTX1 Multi with original Taito IO.zip
@AlxUnderBase thanks for the second log, I cannot see any errors but I see your TAITO JVS :)
yes , tbh … for me chinesse io is good too, ive seen how its working and is good too .
Anyway ive received with taito jvs io few times onky that message “error no entity …. “ but hit ok and enter in game (this happened rarely only before loading chaos breaker , on tetris everytime i load is fine)
