Hammy
Enlightened
No worries!
Roms:
33 801
3 322
Roms:
33 801
3 322
If the "deluxe sprites upgrade kit" ever happens it will be about another 9/10 roms and a few more chipsIt’s going to be the heaviest multi ever with that many chips!
Check your lines, any damage around the CPU won't help.CPU probably isn't making good contacts and the game doesn't boot..
It will work as normal.What happens if I'll try to use the 12mhz cpu without making the clock mod
36 would be a better numberIt's gonna be time to put the main order in soon 35 is a good number for the 1st run.
That's over 1000 rom sockets alone, think if i were to burn the roms also nothing would get done!
Ive sent the links . Hope & praying for good thingsIf is somebody need a donor , just give me a sign![]()
could you send me the link pleaseIve sent the links . Hope & praying for good things![]()
I think I've just used the same seller for 36x 27C801s, it seemed like a decent enough deal. If the stock level is accurate, they have enough to satisfy two more multi'sJust got x36 801s at -80 speed for £45 (all tested and blanked) Ebay UK seller, so not too bad![]()
Writing, labelling, dumping and checking probably took a good 3 hours. Just wanted to get the jump off. Let me know if there's any bugs in those files and I can re-write.Looking good!
Yes, The rom burning takes a good bit of time due to the number of them.
It was a nightmare getting the files correct, hopefully there's no bugs still lurking in those ones![]()
I can't find any issues with those 801 files , the program roms (322's) are still getting some wax on a mostly daily basis....Let me know if there's any bugs in those files and I can re-write.
100 should be fine and are probably the most common.I'll just pay buyicnow to write em for me. What's the speeds I can shoot for cuz they out of 80s
