I tested two revisions on a 12MHz mobo: 910805 Japan and World. Everything works fine. What problem do you have exactly?Were you able to play King of Dragons? It won't let me start the game. My board is 12mhz dash mobo.
I edited my last message. For this game (on my set) it works regardless of the dip switch settings. But it's better to put everything on OFF to test when there is a problem.I remember I set my dip switch settings to all Off. Did you set all Off to get it to work?
You can do more tests later. The most important thing is to playI tested again. It's working for me now. The weird thing was I set all Off for all Dip Switches but it's still Free Play. Previously I set it to Free Play by setting dip switch C #3 On. Maybe it's not fully set to Off yet. But I'm glad it's working now.
I can only speak about daimakaimura resale DIP switches.I wonder if the dip switch functionality is different?
DIP settings on resale are different than the regular versions. You can use the DIP switches to choose the starting level.
Are you sure (I don't remember that) ? Please, what would be the settings to choose the starting level? (so that I can test as soon as possible)I can only speak about daimakaimura resale DIP switches.
Oh thanks, I'll check that.It's in the regional differences thread: https://www.arcade-projects.com/threads/capcom-cps1-1-5-regional-differences-in-games.21661/
Thos behavior has already been explained. It happens in the original as well if you have a 12Mhz A Board instead of 10 MHz. It happens only in the main screen. To bypass it, insert only one credit and it will allow you to start the game. Now you can add more credits or players, if you want.that game will reduce down to 1 credit normally, iirc. i know theres one of em on the multi that does
Interesting thanks for this clarification.Thos behavior has already been explained. It happens in the original as well if you have a 12Mhz A Board instead of 10 MHz. It happens only in the main screen. To bypass it, insert only one credit and it will allow you to start the game. Now you can add more credits or players, if you want.
