I know what you mean. Those caps will eventually fail, so now that you are at setting it up is a good moment to replace some parts that are bound to fail. I do it only on PCBs or PSU that I know that will fail, otherwise, it's good if it works.That's not what I said at all.I love the comment above, if it works I’ll recap it, if it doesn’t I’ll replace it :lol:
My partner has guts to go straight to that. Using my CyberLead JAMMA adapter for it for now. It's almost exclusively running this, Simpsons, Sunset Riders, Parodius, and Gradius games. He jokingly wants to bring his Gradius Bubble System over and put it in, I don't even want that in my houseI'm loving this pic from @Cereth on Twitter. In my mind Turtles in Time was the first game I'll be putting in my Windy 2 when it arrives (after testing on a cheap PCB of course).
The illuminated blue with the Windy II logo looks so dope!
The Happ adapter I had was made by @FrancoB several, several years ago. Also, there is a French seller making those adapters on eBay. I don’t think his have a connection for -5v while Franco’s does.Egret II Update:
- Yellow touch-up spots just laughed at Goof-off and paint thinner.
- Will mix up a batch of retrobright and if that doesn't work, I am probably going to tear it down and repaint the sucker anyway.
- I am definitely having issues with the E2 PSU.
- Furthest I can turn down the voltage without load is 5.7vdc-5.9vdc. 12vdc and -5vdc are ok.
I have extra CPS2 and NAOMI boards, so what the heck, I plugged them in. SFA in attract mode doesn't show the character sprites. All the backgrounds, overlays, SFX are there. MvC2 gets just past the Capcom logo as the music starts to wind up and gets stuck in an infinite loops. I am going to re-cap it and see if that helps. If not, looks like Peter Chou to the rescue once I get this bad boy home next month. @radiantsvgun, please PM me those connectors. Hope those boards aren't toasted.
Good news is the marquee light works and the monitor looks pretty good. Below are some snaps with the TPG driving the monitor. I am getting some wavy crawlies across the screen. I guess the MS9 doesn't like Crafty Mech 15khz. I didn't see those in the CPS2 or NAOMI screens. A tiny bit of convergence issues as well:
Windy II Update:
- Outside, the Windy II looks pretty good. Inside it pretty grimey. Matter of fact, the Windy looks worse than the E2 from the inside
- Lots of oxidation everywhere too
- Monitor looks like it is about to die
- Does a chirp, collapses on itself horizontally, then springs the image back into form
- What do you guys think that is?
Filter cap?EDIT: Looks like it is a HOT that is going out at best, flyback at worst- Oh, stupid me, I forgot to bring a laptop with a VGA connector to test with external video, because..........
- While voltages tested good off the PSU
- Plugging in the NAOMI brought me to a JVS I/O error
- Looking at the JVS I/O board, there is oxidation everywhere
- I think I see a cap leaking
- I ran a separate USB cable to the from the I/O to the NAOMI, still no luck
Please understand this practice. There is no useful information gain by measuring switch power supply this way when you have guaranteed improper function by operating without minimum current load require for regulation. if you don't want plug pcb in hook 1ohm 50watt resistor on your DC +5v and DC ground and remeasure results.I am definitely having issues with the E2 PSU.
Combatribes is my trusty test PCB. It's survived everything so far.I just keep some shitty/cheap PCBs on hand for testing cabs.
I have an old pandoras box that someone gave to me that I used as a test pcb for a while, I have a logic pro2 with some glitchy graphics (worth only $16 working so... ) that I also use
Thanks. I'll remember to always have such a resistor handy. When the cabs arrived, Hatsune Mike was telling me these PSU's were awful. He was right.Please understand this practice. There is no useful information gain by measuring switch power supply this way when you have guaranteed improper function by operating without minimum current load require for regulation. if you don't want plug pcb in hook 1ohm 50watt resistor on your DC +5v and DC ground and remeasure results.
From your PM, I was hoping for just links to the connector housings. I have an upcoming purchase from mouser I need to make anyway. So if anyone knows just what the connectors are on the E2 PSU, please let me know.The Happ adapter I had was made by @FrancoB several, several years ago. Also, there is a French seller making those adapters on eBay. I don’t think his have a connection for -5v while Franco’s does.
I will. And don't sweat it too much brutha. I am sure the spacing the pins is standard. I'll just pull out the cheap Harbor Freight callipers and do some measuring, then match it to a connector series that works. Post the info here when I find out. Sucks I can't work on these cabs till next year. They are still at my buddy's place.@acblunden2 you should reach out to FrancoB and see if he still has his schematic. I have no idea what those connectors are.
