Ok bro, sending these your way to test fitment, etc.Stunning!!!!!!
I need another set of eyes on these.
Nice, send me a pic with some measurements and Ill send you a revised top plate, I didnt have standoffs that fit, dont have any larger than M3 so had to go from rough measurements.Overall fitment is great, one minor suggestion with top connector not lining up with the clip cut out's. Cut out should be edge to edge. Bottom cutout is perfect btw.
So this outline should work?
Ok done, will send it out tomorrow your way.Yes this should work.
Awesome thanks!Ok done, will send it out tomorrow your way.
I see what you mean, Ill make the changes. How are the alignment of the holes for the buttons? I was gonna 3D print some buttons, or maybe make some from acrylic rods.
Ill send you another top plate on me. Thanks for testing it
I would be able to do that. I will first try with a few different SD's to play around. If not, i could replace the slot. What part number did you use for this exact slot?First time I see that. Most probably the microSD slot went broken. If it's not that, then it's something else, which is not good.
Are you able to change the microSD slot?
