VodkaGobalsky
I got replies from the pings.
- But i figured this is a the wrong thread anyway, since the OSM has its own thread
It says "checking network", but the WiPi never shows it online.Does the setup menu of the Naomi show "network"? - If not try to reseat the netdimm.
1. yep tried a few and no good1- You did try another network cable yes?
2- is your wipi configured in wifi router or hotspot direct?
3- you know the blast is meant to power a naomi right? no need for that external powersupply![]()
I just directly connect the WiPi via ethernet to the netdimm.Sadly Naomi setups can be faulty without a reason.
- check your wipi configuration if the wipi LAN is still in the same network as die netdimm
- check if you really use a crossover cable / cable is not faulty
- if you own a network switch: attach netdimm and the pi to the switch to check if both devices utilize a connection (since the netdimm itself does not have any leds)
- since your netdimm shows "network settings" hardware-wise everything should be fine. (if the netdimm is not seated correctly the network setting disappears or you get an error)
- Did you change anything on hardware- or software since the last working state?
I tried changing the ip addr on the netdimm and adding it as a new device in the WiPi. Is that what you meant?I had the same problem not too long ago.
Reconfiguring the network settings to a new network segment on both sides solved it for me.
Not exactly - I changed the LAN interface configuration to 10.1.0.0/24 instead of the 10.0.0.0/24 subnet.I tried changing the ip addr on the netdimm and adding it as a new device in the WiPi. Is that what you meant?
Aah okay I think I follow what you mean. Still no good thoughNot exactly - I changed the LAN interface configuration to 10.1.0.0/24 instead of the 10.0.0.0/24 subnet.
So for example 10.1.0.1 for the wipi and 10.1.0.3 for the netdimm and connected everything to a switch to rule out a cross over cable problem.
So I have the netdimm connected to my nwk switch (which my computer is also) and then try to use transfergame.exe. It just times out when trying to connect.Hmmm. can you connect a pc and try transfergame.exe? This would eliminate the rasberry and perhaps confirm if your netdimm or the pi is the issue?
