Tubes with bonded yokes are hit-or-miss, in my experience. If the purity/convergence is set with a static magnet and not adjustable rings, don't bother at all.Has anybody in here successfully removed a bonded yoke from a consumer tube and replaced it with a yoke from an arcade monitor?
I have two JVC 27” consumer sets with beautiful pictures and a high-TVL count that I would love to throw into an Astro City if possible, but the yoke impedance is way off and to do a swap I will need to figure out how to remove the bonded yoke.
Just wondering if this will be worth my time or if I’m in for a world of pain.
Try this method, @kikasoTubes with bonded yokes are hit-or-miss, in my experience. If the purity/convergence is set with a static magnet and not adjustable rings, don't bother at all.Has anybody in here successfully removed a bonded yoke from a consumer tube and replaced it with a yoke from an arcade monitor?
The few tubes I've tried that had bonded yokes, I was able to get them off by using a heat gun on low. It will be slow going, and more often than not you'll need to peel and break apart the bonding from the tube since it will not come off in one piece. Just blast the yoke/windings directly with the heat gun and start taking it apart piece by piece.
You are right, sir!Those are just the rubber wedges. That doesn't mean the yoke is bonded. Undo the screw at the base of the yoke and twist the yoke. If it's just silicone between the wedges and the yoke, the yoke will just come off.
Just to give you heads up, there is a new tori listing for 20" philips near you in KemiNo worries, the hunt continues and my friend wants this as a retro gaming tv so it still goes to use
Thanks! Just messaged the seller about itJust to give you heads up, there is a new tori listing for 20" philips near you in KemiNo worries, the hunt continues and my friend wants this as a retro gaming tv so it still goes to use
If by some crazy chance it has the wrong neck connector on it, I want it!!Thanks! Just messaged the seller about it
Yeah and I just found out that it is the same seller who sold me the wrong size 21" TV earlier He was sorry about it and tries to get that new one for me in Oulu in 2 weeks. I let you know what kind of neck it has when I get it!If by some crazy chance it has the wrong neck connector on it, I want it!!Thanks! Just messaged the seller about it
I like how the seller is advertising it with pics of Gunstar Heroes Treasure Box. A man of class.
I've never seen the latter. I suspect they're very uncommon. You can always ask for a pic.What I read Hantarex MTC9000 can have this or then B8-274 type connector?
Ok, so should be pretty safe. I think you said to swap that MTC9000 flyback with a HR702, why is that?I've never seen the latter. I suspect they're very uncommon. You can always ask for a pic.
Here are some pictures. They were paired ready so it was easy for me to make my first ever inductance measurementSince you have a ESR20, you might as well double check the inductance of the yoke to be sure.
How are the wires attached to the yoke?
