Good to hear!My battery is definitely working. Remembers the time and my Unibios settings.Is your battery working ?
Can you try a different microSD like Samnsung or Sandisc from a good trusted source?Hi Darksoft,
Sorry for being so late to answer.
In the folder games, there is folder of several games. Each games's folder include 6 files : crom0; fpga, m1rom, prom, srom and vroma0
Folder game also include folder MENU in which there is 5 files : crom0; m1rom, prom, srom and vroma0
The folder update is empty.
I download all the MVS packs of the forum.
Thank you for your help.
Are you using a MAC?Need help...
Just got this today from HighScoreSaves.com and for the life of me I can't get this thing to work on my Time Harvest CMVS. I got it to load the menu in the beginning. I went to update it and it's never really worked since. Now i'm stuck on "checking games". I've tried flashing the firmware and i'm not getting anywhere.
Things I have tried:
1. Multiple memory cards from Samsung, Sandisk to Kingston formatted with SD Card Formatter
2. I've tried all the firmware updates and menus on the firmware thread
3. Put the firmware updates and menu updates on the memory card as directed
example: SDCARD:/update/firmware.img
/update/top
/menu (with the menu files in it)
4. Did the NVRAM reset before doing the updates by powering the system on with no cart and getting to the menu where it says to reset backup ram and hitting A+B+C and it brings you to the next menu.
I've seriously been trying to get this to work for 3 hours. I'm losing my mind with this thing.
If I revert to an older firmware it gets stuck on "flashing games" and never gets to the menu.
It's a 12V 3A power supply. I've tested it for 5v at the jamma connector.Good to hear!My battery is definitely working. Remembers the time and my Unibios settings.Is your battery working ?
What kind of PSU do you have ? The multi cart requires more current than a normal cart.
I'm just using Windows 10. I don't ever use my MAC for things like this. I've tried loading the firmware probably 200 times last night. I've put them on the SD CARD in the format I listed before.Are you using a MAC?Need help...
/update/top
Also when updating...remember that menu+Firmware go together, you can't mix files from different versions.
data:image/webp;base64,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 it SDXC or SDHC? Exact model please.
Well, My MV1b stopped working yesterday. Maybe it was just that. When i turn in on, a lot of colored little squares appears. So bummed now!@seikenflyer a few minutes is all it takes.
I have so many 4GB & 16GB memory cards. Most are SanDisk. I'll try those tonight.IMO mMust be the card...
Do you have a smaller card like 4Gb that you could try with? Then you know for sure that it works with one card and the issue is with those Samsungs.
I'm at work right now for another 4 hours. I'll see what happens when I get home. I've been thinking it's the Micro SD card slot since I have tried at least 4-5 different cards that are SDHC.thats imo clearly a problem with the microsd. It could be also the microsd slot.
i'll definitely try that when I get home from work. Thanks for the response.@rivlez When it gets stuck on the "checking games" screen try holding up+start for a few seconds to see if it will get you to menu.
So I got it to work the first time I did the steps with a 4GB Micro SD card but the same thing as last time. I press C to look at the menu and the menu never comes up. It's like each memory card can only be used once and then it won't work again. Right now I keep getting stuck on "Initializing filesystem...". It won't go past that screen. Any idea why the menu won't show when I hit the C button?thats imo clearly a problem with the microsd. It could be also the microsd slot.
This unfortunately did nothing for me.@rivlez When it gets stuck on the "checking games" screen try holding up+start for a few seconds to see if it will get you to menu.
